ISAT error and ddasac failure
Old   July 15, 2003, 11:56
Default ISAT error and ddasac failure
Stephen Mattick
I'm trying to use FLUENT v6.1 for some supersonic combustion research and am getting one of the following errors:
(1) Error: isat_table init: xscale must be positive: x=0.000000e+00 This error happens when using the EDC model w/ ISAT enabled.
(2) Error: rmap2: ddasac failure. This happens at varying # of iterations when I use the EDC model w/ direct integration (w/o ISAT).
Any suggestions on fixing the problem would be appreciated.
Thanks.
--Stephen
Old   July 18, 2003, 13:57
Default Re: ISAT error and ddasac failure
KT
Try to set the error tolerance lower (e.g. 1e-4 or lower) or use direct integration. If that doesn't work, most likely your case cannot be solved by the solver or it doesn't have a converged solution.
