DEFINE_GEOM UDF Problems
Old   August 14, 2003, 13:16
Default DEFINE_GEOM UDF Problems
Pat
I'm am having trouble getting the UDF DEFINE_GEOM to work properly. I would like to use the UDF to make a flat plate deform into a different shape over time. I have compiled the UDF properly and have hooked it into fluent as outlined in the UDF user's manual.
However, when I view the mesh motion the flat plate does not deform and I believe that my UDF is not even being read (I inserted an "error" message to check and see if the UDF was functioning, and the error never came up). I'm using WinXP and Fluent 6.1.18.
If anyone knows what the problem may be please respond. Also if anyone has a DEFINE_GEOM UDF that has worked, I would like to see it. I can share my UDF if necessary.
Thanks,
Pat
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
problems with UDF to set contact angle poiuy219 Main CFD Forum 0 April 30, 2009 10:43
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 11:29
