meshing
Old   August 21, 2003, 04:31
Default meshing
prasat
What is the difference between fluent mesh and Gambit mesh ? If they are different how to convert one format into other. prasat
Old   August 21, 2003, 05:28
Default Re: meshing
ap
You can't create a mesh in FLUENT. You can only adapt it on the basis of the solution you have already obtained, using adaption tools.
GAMBIT is the mesh generator for FLUENT. You create your geometry in GAMBIT, apply the mesh end export it as a .msh file.
FLUENT directly reads .msh files through the File->Read->Case menu function, so you don't need any conversion.
Hi
ap
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
