August 26, 2003, 08:12 |
Fluent Directory
How do you set up / change the Fluent directory to which all .cas and .dat files are saved? At the moment, all my stuff is just getting saved to C:\.
Apologies if this is a daft question - I'm new to this! |
September 1, 2003, 09:48 |
Re: Fluent Directory
You can select the directory where to save your case and data file in the same panel in which you specify the name of the files you want to save.
Regards, Ale |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
