Mesh Qulaity Criteria
Old   September 10, 2003, 10:38
Default Mesh Qulaity Criteria
Rony
Hello Fluent Users,
I have a concern about the quality of the mesh I generate. We all know a good/bad mesh can make or break your CFD career. What are the criteria of a good mesh. Skewness lower than 1. Should it be really equi angle or equi size, what should be the maximum granularity ratio ( for example fluent says your element size should not vary more than 5:1), How many minimum elements we need across a volume to minimize numerical diffusion. Does it has to be the same way for all volumes, or should it be perpendicular to flow path. What about Non Conformal meshing, From time perspective, it is easy to tet mesh (unstructural) and move on, reduce cycle time, how many non conformal surfaces you can have in a geometry, any limitations on it. If some one has any idea about these criteria it could be great help if you can share your thoughts with us. Advanced Thanks. Thanks Rony
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
