Mesh around a 3D airfoil
Old   September 22, 2003, 11:12
Default Mesh around a 3D airfoil
Pat
I have to create the mesh around a 3d swept wing. I need it to be structured. I have tryed so many times that I have no more ideas to make it. Any suggestions or web address where I could have some help?
I have already made it with gambit for a classical wing. It was ok...
Thanks
Pat
Old   September 25, 2003, 05:07
Default Re: Mesh around a 3D airfoil
Chetan Kadakia
Break up the area around the airfoil into seperate volumes. You may also need to use the cooper scheme.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
getting airfoil surface to be recongized for tri mesh josip76 ANSYS Meshing & Geometry 4 June 9, 2011 22:48
[ICEM] Can’t get 2D Blayer in hex mesh to be accurate O-block around airfoil josip76 ANSYS Meshing & Geometry 2 June 4, 2011 18:03
2D airfoil optimisation: the mesh Marta Main CFD Forum 5 February 6, 2008 01:07
