Question for Induction heat
Old   October 1, 2003, 00:01
Default Question for Induction heat
J.W.Ryu
Hello all,
I am considering heat and flow simulation including induction heat mechanism, such as Iron melting with high/low frequency induction heating. Does anybody have experience similar model to this? If yes, could you let me have your idea or method?
Thanks and regards,
J.W.Ryu
Old   October 17, 2003, 12:27
Default Re: Question for Induction heat
dr
hi,
i suggest you go to the following adress: http://www.cranfield.ac.uk/cww/ccc/d...tg/node278.htm
this tutorial might help in your case
i hope this helps
dr
Old   October 20, 2003, 08:08
J.W.Ryu
Dear Mr/Ms. Rochaya,
Thanks for your suggestion. But, I can not access adress that you suggested. Could you let me have correct adress?
Thanks and regards,
J.W.Ryu
Old   October 20, 2003, 10:07
dr
hi,
you can find te same tutorial on this adress:
http://p2chpd-cluster.univ-lyon1.fr/...tg/node278.htm
I hope this helps
dr
Old   October 23, 2003, 08:22
J.W.Ryu
Thanks for your advice. I have read this tutorial, and have tutorial book. What I want to know was the method to simjulate heat transfer from induction heat source. Probably my provious post made you confusion. I am sorry.
J.W.Ryu
Question concerning the heat capacity Cp tangd OpenFOAM Running, Solving & CFD 1 July 10, 2006 03:25
Simple 2d Heat transfer question Richard FLUENT 2 January 18, 2006 22:49
VISCOUS heat dissipation Joseph CFX 0 October 1, 2004 08:52
Heat flux question? Mark Main CFD Forum 0 February 13, 2004 09:03
