Using c_face_loop
Old   October 16, 2003, 12:10
Default Using c_face_loop
Ajay
I am trying to write a UDF which print outs the area vectors of the boundary faces could somebody point out why i am getting non -integer subscript expression : unsigned char error when i try interpretting my udf ?the line number where the error occurs is in marked with ******'s Thanks , Ajay
DEFINE_ON_DEMAND(area_on_demand_calc)
{ int index;
real cell_cordi[ND_ND],a[ND_ND];
Thread *t;
Thread *tf;
cell_t c;
face_t face;
d = Get_Domain(1); /* Get the domain using Fluent utility */
if ((fpt3=fopen("mean_shear.dat","w"))==NULL)
printf("Cannot open the file\n");
return;
/* Loop over all cell threads in the domain */
thread_loop_c(t,d)
/* Loop over all cells */
begin_c_loop(c,t)
********** c_face_loop(c,t,index)
tf = C_FACE_THREAD(c,t,index);
if (BOUNDARY_FACE_THREAD_P(tf)== TRUE)
F_AREA(a,face,tf);
fprintf(fpt3,"%d ",index);
fprintf(fpt3,"\n ");
end_c_loop(c,t)
} fclose(fpt3);
Old   October 17, 2003, 04:03
Default Re: Using c_face_loop
qubek
I have the same problem and I found the solution searching this forum. The problem is that if you use c_face_loop you can't interpret your UDF but you have to compile it.
Old   October 17, 2003, 13:21
Ajay
Thanks a Ton !
