Two gasses mixture
Old   November 7, 2003, 10:49
Default Two gasses mixture
Rahman
Hi, Would you give some sort of guidelines about simulation of two gas that will be inter into a high vacuum cylindrical chamber? I have to mainly see the relative portion of each gas and density of this mixture at the different portion of the chamber.I have to use two inlet for two gas and one outlet. I will be very glad to you if anybody give some information (i mean from where i have to start, any supporting tutorial, any documents) about this type of simulation with FLUENT. Thanks.
Old   November 7, 2003, 11:01
Default Re: Two gasses mixture
mateus
Hi!
You are probabilly have do work with mixture multyphase model. Go trough the tutorials for multyphase flow simulations (all of them are good for understanding multyphase), to get the idea what you have to do.
regards
MATEUS
Old   November 7, 2003, 12:32
ap
I agree with Mateus, you're working with gases so your two fluids have the same density: the Mixture model should work properly.
If you don't obtain good results with it, switch to the Eulerian model, which should be more accurate, solving a full set of transport equations for each phase.
Hi
ap
Old   November 8, 2003, 06:04
emre
Hi, You can simulate this kind of problems by just solving species transport equations, it is fairly easy unless there is reaction between the gases. Regards emre
Old   November 10, 2003, 06:33
Rahman
Thanks a million to all for your quick response. I will start according to your suggestion.
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 08:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 08:14
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 22:14
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 06:04
Burning a CH4-H2 Mixture Jonathan Lemay CFX 2 November 12, 2007 17:01
