Local surface contour line plots
Old   November 9, 2003, 23:26
Default Local surface contour line plots
Nandu
I have written a scheme script to create surface planes within a 3-d simulation domain and generate contour plots onto these surfaces. I am however unable to generate contour plots with the local variable values on the surfaces. the default 'global' values seem to be getting used all the time. is there some manner in which i can avoid this without having to calculate the local maxima and minima of the variable on the surface each time i wish to place a contour plot on it?
regards Nandu
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
