heat transfer with porous block in fluent
Like Tree2Likes
  • 2 Post By co2
Old   November 23, 2003, 04:23
Default heat transfer with porous block in fluent
Salhi Rachid
Dear users, I want use Fluent to mdel heat transfer and fluid flow in channel containing a porous block (i.e.: channel partielly filled with a porous media). I can't sepcify the porous zone and particulary the interface fluid-porous region, I need your help
Old   November 24, 2003, 23:42
Default Re: heat transfer with porous block in fluent
ccc
hi Salhi,
Does you specify two zones in Gambit, one for fluid and another for porous media?
good luck.
Old   November 26, 2003, 13:41
co2
Dear Salhi,
I am not exactly able to visualize your geometry but porous zone option is available under fluid material type - It is just a matter of checking a box.
I have had success is creating the interface between the fluid and porous zone by doing the geometry creation in gambit right. you need to use split option intelligently and specify the boundaries as walls. Then when you export your geometry into fluent, you will see a wall and wall-shadow appearing say wall-13 and wall-13-shadow. You click on wall-13 and change the boundary type from wall to interface. that results into disappearance of the shadow and an interface creation between your porous and fluid zone - allowing mass, momentum and energy trasfer.
I hope my note helps you and you are able to move ahead in your research ! good luck.
amir_hiwa and KiteKathy like this.
heat transfer in porous media Miko Siemens 10 February 16, 2022 07:13
Heat transfer in porous domain CFX V12 Hashmi CFX 0 August 15, 2009 12:05
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
REG POROUS MEDIA HEAT TRANSFER Rashmi Venkat FLUENT 6 June 1, 2006 05:13
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
