how to make fluent wait?
Old   December 4, 2003, 05:45
Default how to make fluent wait?
Stanley
Hello all of you! Is it possible to make fluent wait until a needed file will be created? What do you think?
However, thank you in advance
Wish I know it! Stan
Old   December 4, 2003, 11:01
Default Re: how to make fluent wait?
ccc
hi Stanley,
really interesting question!
A possible way, I think, is to insert a loop into one of general define macros, for example, DEFINE_AT_END. The following codes may work.
FILE *file=NULL; char *filename[40]="kddahe.data";
while (!file)
file=fopen(filename,"*"); // you should check function definition to find suitable value for the second parameter, "*"
good luck
Old   December 4, 2003, 16:43
Ajay Rao
What about the EXECUTE command which allows you to execute a command after N number of iterations.May be this could be used , I have never tried though.
Ajay
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent equation error?!? TOM FLUENT 6 July 15, 2002 03:24
