December 5, 2003, 12:25 |
streamlines in 3D
In 2-D fluent gives an option in the drop down menu for plotting contours of streamlines, but in 3-D how could one get the stream line patterns ( Stream surfaces rather ) Any idea ? Thanks, Ajay
December 5, 2003, 12:27 |
Re: streamlines in 3D
You can't, streamlines (countours of the streamfunction) are only defined/available in 2D. In 3D you'll have to use path-lines.
December 5, 2003, 17:02 |
Incompressible flow - R.L Panton has a section on streamlines and streamsurfaces for 3-D flow Its chapter 12 in my old edition. I tried using Path lines but not getting good results. ( path lines would represent streamlines in 3d only in the steady case ) Regards, Ajay
[CFD Post] Surface streamlines not located where needed | siw | CFX | 1 | July 7, 2011 19:13 |
How to get Streamlines to interact.? | stephen__white | CFX | 2 | April 12, 2011 17:00 |
Streamlines under Moving reference frame; Spiral streamline from Tecplot | aiqch | Tecplot | 2 | October 29, 2009 23:27 |
Custom streamlines - only 2 velocity components | bernarde | STAR-CCM+ | 5 | August 24, 2009 07:18 |
STAR-CD, moving grid and streamlines | Mohamed GUEROUACHE | Main CFD Forum | 1 | September 13, 1999 13:33 |
