Influence of relaxation factor on the final result
Old   December 25, 2003, 22:16
Default Influence of relaxation factor on the final result
bylin
I am computing a turbulent flow field using standard k-epsilon model with source terms added to the momentum equations. My problem is that it converge only when I reduced the relaxation factors of continuity and momentum equations. I want to know whether too small relaxation factors,like 0.05,will affect the final physical results.
Old   December 26, 2003, 08:18
Default Re: Influence of relaxation factor on the final re
bylin
OH!It's false convergence!I've just examined the residual fields,it's still large for the momentum equation.
Old   December 26, 2003, 18:03
Ashu
You can either speed up to the solution fast or slow depending on the value of relaxation parameter. If you use high value it would want to reach the final value fast, but sometime could diverge the solution. Special cases you have to see what's happening to the solution. You can flip the relax. parameters for pressure and momentum to converge fast, may work sometimes....
Old   December 26, 2003, 21:38
bylin
Thank you,Ashu!I'll try it.
Old   December 27, 2003, 10:32
Sijal Ahmed
they have no influence on results
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
