UDF for 3-Dimensional geometry
Old   January 1, 2004, 01:49
Default UDF for 3-Dimensional geometry
vimal
I want to write a UDF for parabolic velocity proifles for flow in a 3-Dimensional pipe. Can any one suggest me.
Old   January 2, 2004, 16:26
Default Re: UDF for 3-Dimensional geometry
ap
It's just the same as in 2D. Write the equation of the paraboloid which represents your profile.
Suppose your flow is oriented along the z axiz. Center the inlet with the origin of your reference system. Your profile will assume the simple form:
z = a*x^2 + b*y^2 + c
Use the macro F_CENTROID to retrieve the cell centroid coordinates, with a line like the following:
F_CENTROID(x,f,t);
where x is an array of dimension ND_ND, f is the face and t the thread. Then, you can put
x = x[0];
y = x[1];
and use
F_PROFILE(f, t, i) = a*pow(x,2) + b*pow(y,2) + c;
replacing a, b and c with their values.
Hi
ap
Old   January 5, 2004, 13:09
co2
ap,
why do you put Hi
at the end of your message?
Old   January 8, 2004, 10:09
ap
Just a nice and short way to say "Hello and good work". A smile always helps.
Hi
ap
Old   January 8, 2004, 14:50
hatta
Hi everyone,
Suppose i am using the velocity at the inlet of the st. pipe is 0.45 m/s. The ID of the tube is 0.0102 m, by using these values i made a UDF for 3D as
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y,z; face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[0];
z = x[1]; F_PROFILE(f,thread,position)=0.45-y*y/(.0051*.0051)*0.45-z*z/(.0051*.0051)*0.45;
} end_f_loop(f, thread) }
when is read the velocity at the inlet of the tube it shows 2400 m/s. there is somthing wrong, can you please suggest me what is wrong here.
Old   January 8, 2004, 18:51
ap
If your velocity profile is function of y and z coordinates, these two lines are wrong:
y = x[0];
z = x[1];
The x vector contains in the order x,y,z coordinates. So:
x[0] -> x coordinate
x[1] -> y coordinate
x[2] -> z coordinate
To check the paraboloid equation, just plot it in a softwnare like gnuplot.
Hi
ap
Help Parallelizing UDF AndresC FLUENT 0 February 25, 2010 15:50
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
udf for velocity profile in a geometry having two inlets shubham208011 Fluent UDF and Scheme Programming 0 April 6, 2009 15:13
UDF macros and updated mesh geometry Maziar Mahzari FLUENT 1 November 1, 2005 06:29
UDF : Chemical Reaction in Catalytic Converter adhimac FLUENT 1 March 27, 2001 14:04
