domain and superdomain ???
Old   January 16, 2004, 04:11
Default domain and superdomain ???
thomas
Hi everyone, I am trying to implement a source term only in the first range of cells after a wall. The source term is hooked via energy equtaion for water (Euler-euler solver). What i need is to access the thread of teh wall (called tf_wall). The ID of teh wall is ID =2. Here is the part of the UDF i wrote:
DEFINE_SOURCE(heat_flux,cell,thread_water,dS,eqn)
{ Domain *domain;
Thread *tf_wall,
int ID =2;
Thread *tf_wall = Lookup_Thread(domain, ID);
Doing that i got an error message when i want to use the Thread tf_wall. As my define source is hooked up in the energy equation for water i wonder if the '*domain' pointer is the right one to put in the Lookup_Thread(domain, ID) macro. As far I understand my *domain is the sub_domain referring to water. Which domain should I use to get my wall thread using Thread *tf_wall = Lookup_Thread(domain, ID) ? Do i need the mixture_domain pointer to make it work?
Thanks
Old   January 16, 2004, 13:39
Default Re: domain and superdomain ???
thomas
I have Found my mistake thanks
