Changing BC
Old   January 14, 2004, 16:45
Default Changing BC
Riham
I want to change one boundary type into another boundary type during computation automatically and periodicly by Fluent,for instance,changing the velocity inlet boundary to velocity outlet bounary.
Is there anyone to provide some specific help or suggestion?
Thanks a lot!
Old   January 15, 2004, 05:06
Default Re: Changing BC
Andrew Garrard
Already been done. http://www.cfd-online.com/Forum/fluent.cgi?read=16652
Old   January 15, 2004, 05:22
DAE
If you are using the unsteady solver, and you want to change the boundary type at the end of a time step, use a journal file.
DAE
Old   January 15, 2004, 10:34
Riham
Thank you Andrew and DAE for your replies.
Please can you give me more details about my problem, I've never used journal file in Fluent but only in Gambit. and this is my first project in cfd.
Thanks a lot
Old   January 15, 2004, 10:46
DAE
The journal file is used to record commands i.e. record the commands used to change the bc and then modify the and edit the journal as required for your problem. Use the fluent documentation for info on recording journals
dae
Old   January 15, 2004, 20:54
ccc
hi Riham, Adrew and DAE,
I think I am the first one who posted up this question.
first of all, I am sure the feasibility of changing boundary condition, since we can interrupt the computation, change the boundary type and make it run again.
second, it is a good and idea of using journal files, although a little boring, )-:
last, I am considering other methods, for example, by using lisp language since the GUI interface of fluent is written in this one. I know little of lisp.
good luck, everyone. ^-^
energy changing associated with mass changing Martin duan FLUENT 0 August 6, 2011 12:42
changing LES models problem maysmech OpenFOAM 2 August 27, 2010 05:20
Changing orientation of object in Paraview Jochem OpenFOAM 0 July 28, 2010 04:52
Changing contact line tfe FLOW-3D 3 December 8, 2009 02:59
cavitation with changing temperature Elyor Siemens 2 September 20, 2007 09:55
