press value at press outlet BC
Old   January 29, 2004, 11:44
Default press value at press outlet BC
ace
hi can anyone tell, what pressure value to give on Press outlet once the body is attached to the press outlet from the rear and infront press inlet is given as BC and 101325 pascals is given. The case is subsonic compressible.
Old   January 30, 2004, 04:44
Default Re: press value at press outlet BC
mateus
Hi!
The pressure difference between pressure inlet and pressure outlet will give you the desired flow velocity. One more thing. Your body should not be attached to the outlet bc. You will get big problems with reversed flow in this case. You shuld put the outlet bc far away from your body to avoid this.
Regards
MATEUS
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
Impinging Jet. Outlet Boundary Condition Vincent Main CFD Forum 0 December 16, 2003 10:49
