drop fall velocity
Old   January 29, 2004, 11:22
Default drop fall velocity
ozgur
I want to calculate the falling velocity of my drop in 3D VOF model. So far, I've created an iso-surface of volume frac. on the drop, and use surface integral panel to calculate the area-weighted average of Y velocity (the vertical coordinate) over the iso-surface. To be more accurate, I want to use volume integral panel, and do the same averaging over the complete drop volume. The problem is, there is no way to select particulary the volume of my drop, so that I can calculate an average over the all cells in my drop. I can only select the complete fluid zone in my domain. Does anyone have an idea how to fix this?
Thanks in advance
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
Emergency:UDF for a time dependent parabolic velocity zumaqiong Fluent UDF and Scheme Programming 12 March 25, 2010 12:00
Pressure Drop in terms of velocity Arun FLUENT 0 June 26, 2008 07:45
Relationship between velocity and pressure drop harry Main CFD Forum 13 May 8, 2007 06:39
