Off-center peaks in an impinging jet
Old   February 2, 2004, 20:22
Default Off-center peaks in an impinging jet
John
I am trying to simulate 2D slot and 3D square impinging jets(free and confined) with FLUENT. At low nozzle-to-plate spacings and at high Re(say H/W<2, Re_W>10000), experimental data shows an off-center peak in the skin-friction factor and Nu profiles. I tried all the k-eps and RSTM cases (steady) with the standard and enhanced wall functions, but cannot capture those secondary peaks. The nozzle exit BC's are 1-10% turbulent intensity and a turbulence length scale of 0.07W. I also tried the case with fully developed turbulent flow between two parallel plates in the case of slot jets(using k and eps profiles obtained from the flow between parallel plates at the nozzle exit) as the nozzle-exit condition but didn't work either. Any suggestions? Will unsteady simulations help?
Thank you in advance.
John
p.s. Is there anybody running LES using Smagorinsky model and getting good agreement?
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 20:18
impinging jet natesan Main CFD Forum 3 March 17, 2005 05:42
impinging jet natesan Siemens 1 February 25, 2005 03:16
impinging jet data Andreas Abdon Main CFD Forum 4 January 19, 2000 07:40
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 22:11
