DISPLAY ERROR!!
Old   February 10, 2004, 12:13
Default DISPLAY ERROR!!
Alex
I am using a combination of "Hummingbird Connectivity" and "SSH secure shell" to run fluent through the local UNIX machines at my university. Gambit works fine without any display problems. However, when I try to open display window in Fluent, I get the following error message: "Error message from graphics function how_Device_Info: Server does not have GLX extension." If you have encountered similar problem before, will you kindly suggest a remedial measure.
Many Thanks, Alex
Old   February 11, 2004, 09:17
Default Re: DISPLAY ERROR!!
Erwin
Try starting fluent as follows:
fluent -driver x11
Old   February 11, 2004, 09:59
Default No :(
Alex
Thank you Erwin, but you suggestion didn't do the trick.
Again, thanks, Alex
Old   February 12, 2004, 05:32
Rob Hart
What versions of the above software do you have?
I have tried it running fluent via ssh and both Hummingbird eXceed 7.1 and cygwin/XFree86 and it works fine with both.
What do you get if you run xdpyinfo after you have connected to the unix machine. It should give you a list of the server extensions that are available on your X server.
Fluent doesn't need the GLX extension (which is not part of eXceed) but will use it if it's there. (which it is with cygwin/XFree86)
Old   February 12, 2004, 09:40
Default Thank you Rob!
Alex
Hi Rob,
Thank you so very much for educating me about the source of the error. Though I still haven't solved the problem, knowing what is causing it makes me feel much better.
I have answered your questions regarding versions of progammes used (see below). I would be delighted if you can come up with a way to circumvent this problem. In any case, I am very thankful for what you have done.
Alex
Hummingbird Exceed: Ver. 7.1.1.0
SSH Secure Shell: 3.1.0 [Build 235]
Fluent: Release:6.1.22
Graphics Version: 7.07-1
List of extensions include:
BIG-REQUESTS
DOUBLE-BUFFER
Extended-Visual-Information
HCL-DOS-Access
HCLMISC
HCLxperf
LBX
SECURITY
SHAPE
TOG-CUP
XC-APPGROUP
XC-MISC
XInputExtension
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
user defined function cfduser CFX 0 April 29, 2006 10:58
