simulation two phase closed thermosyphon
Old   February 19, 2004, 04:11
Default simulation two phase closed thermosyphon
mohammad reza
i am working on performance of two phase closed thermosyphon.can i use fluent software for simulation of two phase closed thermosyphon? thank you for recoments and guides
Old   February 21, 2004, 06:28
Default Re: simulation two phase closed thermosyphon
ROOZBEH
Hi; In general you can simulate some multiphase flows of some kinds in Fluent. If your phases make a continuose domain, you should use the multiphase model else, you should use the discrete phase model. I think that for your problem you should use the first option. If the surface tracking of phases is important for you, you should use the multiphase VOF model and...
Hope this help you
ROOZBEH
Old   February 24, 2004, 04:33
Default heat tran simulation two phase closed thermosyphon
mohammad reza
can you help me for heat transfer simulation condensation/boiling in two phase closed thermosyhon?
Old   November 1, 2016, 03:58
Vivek Kumar Mahato
ImVKMahato is on a distinguished road
Greetings sir.. I want to simualte a two phase closed thermosyphon.. I have read various jounal papers about it..But I dont know the procedure to set up the simulation. Plz assist.. any help will be very much appreciated..Regards
ImVKMahato is offline   Reply With Quote
Three phase flow simulation Gitesh P Main CFD Forum 1 December 22, 2010 20:59
Three phase simulation of airlift reactor Idtisak CFX 0 February 22, 2008 10:05
How to simulate a closed two phase stirring vessel Jo CFX 1 November 12, 2007 16:29
time and phase averaging simulation data prem FLUENT 0 December 28, 2003 22:15
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
