February 22, 2004, 10:31 |
animation - playback - MPEG
I am using the play back option in animation pannel to write a MPEG file. But the results in MPEG files run too fast .. can some one suggest me a way to control this speed ?
thanks, charu |
February 22, 2004, 23:39 |
Re: animation - playback - MPEG
sir
I am also facing the same problem. But some body suggested me to save each time frame pic as tiff format or some other picture format. After that use some animation sotware like Antechinus Animator to convert all the tiff files to mpeg format. Other than this, is anybody suggest any other better method. - Karthick |
February 23, 2004, 06:30 |
Hi!
The method that you're using is probabbily the best option. Also the output file (movie) will have a much better quality if you make it manually (not directly from Fluent). Regards MATEUS |
Can't create MPEG animation | Jiri Novak | FLUENT | 3 | July 6, 2012 04:47 |
Animation Playback | goma | FLUENT | 0 | January 12, 2011 04:46 |
How to save an animation to mpeg file | jack | FLUENT | 1 | June 25, 2008 13:26 |
animation playback | fadhil | FLUENT | 1 | June 9, 2008 01:01 |
how to playback animation? | wanghong | FLUENT | 1 | April 18, 2005 10:05 |
