UDF ERROR
Old   March 9, 2004, 12:40
Default UDF ERROR
ozgur
Hi all,
I am getting the following error, when I'm making VOF simulation of a free falling drop:
Error: > (greater-than): invalid argument [2]: wrong type [not a number] Error Object: nan
The error comes after the second time step. The UDF is hooked in the fluid BC panel, fixed values, y-velocity. What I want to do is to calculate fall velocity of the drop, and substract this value from the corresponding velocity component of all cells in the domain. The resulting picture then represents the flow field with respect to a refrence frame moving with the drop.
Thanks in advance for any help
here is the UDF:
#include "udf.h"
#include "sg_mphase.h"
DEFINE_PROFILE(fall_velocity,thread,nv) { real fall_vel_drop; real fall_vel_volweighted=0; real vol_tot=0; cell_t c; Thread *t_phase2=THREAD_SUB_THREAD(thread,1);
begin_c_loop(c, t_phase2) {
if(C_VOF(c,t_phase2)>0)
fall_vel_volweighted += C_V(c,t_phase2)*C_VOLUME_2D(c,t_phase2);
vol_tot += C_VOLUME_2D(c,t_phase2);
} } end_c_loop(c, t_phase2)
fall_vel_drop=fall_vel_volweighted/vol_tot;
printf("Volume average y_velocity of drop: %g\n",fall_vel_drop);
begin_c_loop(c,thread)
F_PROFILE(c,thread,nv)=C_V(c,thread)-fall_vel_drop;
} end_c_loop(c,thread)
Old   March 9, 2004, 18:08
Default Re: UDF ERROR
ap
I recently had the same problem with a UDS, when I enable the source term.
Someone told me it's a divergence problem. Actually, setting the verbose option of the solver to 2, I saw the momentum equation residual is "Not a Number" from the beginning of the second iteration. Try to check if this happens to you too.
I'm still working to solve this problem.
Hi
ap
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
