Cross-Shaped Mixing
Old   March 10, 2004, 23:07
Default Cross-Shaped Mixing
Park, Jaehong
I have been trying to get the solution of the cross shaped mixing problem. but there is a problem.. Each side of the inlets is the ethyl-alcohol and the upper side of the inlet is the water. And upper inlet is larger then each side of inlets. After mixing together, the mixiing liquid goes through the bottom outflow. Those liquids are mixed completely, but the mixing liquid is going back to the condition of the water in the outflow . I guess that it seems to be the resulf of the wrong the phase selection. Please tell me the reason and help me to find the good result.
P.S: I use 3D segregated mixture model and Laminar flow
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
mixing quality simulation harry CFX 5 May 8, 2010 14:36
simulate a turbulence mixing flow arya FLUENT 0 August 30, 2007 06:08
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
