April 7, 2004, 10:40 |
UDF: Problem to Incorporate PDE in BC ???
To all Fluent Expert All Over the world,
I am facing problem to incorporate the PDE C_V(c,t) = C_DVDY(c,t) + constant in my velocity inlet. There is not problem during interpretion. However, when i initiate it, the ACCESS VIOLATION warning appear. Here is my UDF, can somebody point out my errors? DEFINE_PROFILE(solute, thread, position) { face_t f; cell_t c; Thread *t; int i; begin_c_loop(c,t) {C_V(c,t,i) = C_DVDY(c,t) + 0.002 ;} end_c_loop(c,t) begin_f_loop(f,t) {F_PROFILE(f, t, position) = C_V(c,t,i) ;} end_f_loop(f, t) } Thanks alot... especially To FJ, Thomas , ady From KKLAU |
April 8, 2004, 06:06 |
Re: UDF: Problem to Incorporate PDE in BC ???
Hello, Your UDF is very confusing and it is not surprising you get an access violation message ...
1- go to read the documentation about how to use a DEFINE_PORFILE macro http://www.fluentusers.com/fluent61/...udf/node71.htm 2- C_V(c,t,i) does not exist ! what 'i' represents ??? also C_V(c,t,i) = C_DVDY(c,t) + 0.002 is confusing. C_V(c,t) and not C_V(c,t,i) is a macro which only allow to get the velocity at each cell center, nothing else. SO to do what you want to do you have to define a variable and write variable=C_DVDY(c,t) + 0.002 and then F_PROFILE(f, t, position) = variable 3- Then think about at which cell you need to get the data C_DVDY -> all the cells or just the adjacent next to your noudary condition ??? Obviously it is a the adjacent range of cells next to your BC. So you have to define a specific thread and cell ID for this range of cell which in your case *t=THREAD_TO(f,thread) and c=F_C0(f,thread). Making these changes i am sure it is gonna work ... at least at the initiatilization. Good luck ! Thomas |
UDF compiling problem in Flient 6.3 | jeevan kumar | FLUENT | 2 | February 25, 2009 00:43 |
UDF using problem, error happens-heip!! | Michael | FLUENT | 1 | December 9, 2008 07:51 |
UDF PROBLEM | anant | FLUENT | 2 | January 17, 2007 00:15 |
I have problem of UDF with turbulent premx source. | Z | FLUENT | 0 | February 16, 2005 03:34 |
UDF problem | chiseung | FLUENT | 4 | January 10, 2002 09:58 |
