How to use UDF to define a moving wall
Old   April 12, 2004, 02:52
Default How to use UDF to define a moving wall
lingo
emma,Ady and others:
I met a problem.When I activate the Dynamic Meshing and OK,someting as follows appears in my console window:
"Could not check out fluent-mdm-beta: No such feature exists Feature: fluent-mdm-beta License path: D:\FLUENT.INC\license\license.dat; FLEXlm error: -5,357 For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
Error: unable to acquire a license for the moving/deforming mesh model.''
what's wrong ? How to solve it?
another question: I only can activate the "parameter"in "Dynamic meshing" ,how to activate "the zones" in "Dynamic meshing"?
Thank you for your help!
Default Re: How to use UDF to define a moving wall
lingo
Hi,Guess and other friends:
I still don't catch ¡°THREAD_VAR(tc).fluid.omega = your function¡±.I know little about the variables in Macro¡°DEFILE-ADJUST¡±. I try to write a udf :
#inclue ¡°udf.h¡±
DEFILEA¡ªADJUST(my£*adjust,d) { Thread*t; cell-t c
thread -loop-c(t,d) { begin-c-loop(c,t) THREAD-VAR(tc).fluid .omega=5*sin(5*t); end-c-loop(c,t) } }
Can you check it for me? Thank you very much.
Old   April 13, 2004, 04:58
emma
Hello, Lingo,
When you use "dynamic mesh modeling" in fluent, you should add a line "#include "dynamesh_tools.h".
Regards,
Emma
Old   April 13, 2004, 23:05
lingo
Hi,emma:
Thank you for your advice.Yesterday I found several udf examples about DEFINE_CG_MOTION(name,dt,vel,omega,time,dtime).
I never found document about ¡°dynamec meshing¡±and ¡°DEFIFE_CG_MOTION¡±in my Fluent6.0(maybe i miss it,but I examined carefully, In Fluent6document\fluent6.0\help\pdf\udf)¡£ I thirst for the document.Can you send it for me in E_mail or provide me the website to download it (if permissible)?
Thank you very much!
Old   April 14, 2004, 04:14
emma
Hi, Lingo,
You can search the correpondent documentation in internet with "google". Just write the key words, such as " fluent6.0 dynamic mesh manual" in the dialog box, you will find it. About the explanation of the macros for dynamic meshing and how to use them, you could find them in fluent 6.1. See fluent 6.1 User's guide and UDF manual. You'll find them.
Good luck!
Emma
How to use UDF to define a moving wall Big Stone FLUENT 14 February 13, 2021 07:24
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
