Run Fluent on the network
Old   April 21, 2004, 08:46
Default Run Fluent on the network
Kim
I run Fluent now on the network of the University. (I don't know if I express correctly --; I have problem with compiling of UDF.
For example, I meet always error massage as below, but I don't know how to correct or write the path name.
Opening library „libudf"...
Error: open_udf_library: A file or directrory in the path name does not exist.
Error Object: #f
I've written an e-mail to administrator of the network, but received no answer till this day.
Is there anyone who has experience with such a case?
Old   April 21, 2004, 16:02
Default Re: Run Fluent on the network
co2
are you using microsoft vc++ compiler? or dot net compiler -- there are two seperate ways to compile your UDF in these two cases.
Old   April 23, 2004, 08:08
Kim
Thanks a lot for your answer. My computer has microsoft vc++ compiler 6.0, and I think I can also use the net compiler. However, I have little experiences of C compiling, so I want to know all two separate ways. Can you help me?
Fluent Parallel on network ANDENG FLUENT 2 February 28, 2011 02:21
Cannot run fluent 12 kbaker ANSYS Meshing & Geometry 6 February 20, 2011 18:11
Run Fluent in Linux Shamoon Jamshed FLUENT 3 October 26, 2009 11:12
Processor to run FLUENT rashid FLUENT 0 July 22, 2008 00:00
Run a shared memory parallel version on a network? Cheng MuLin FLUENT 1 October 23, 2001 03:58
