Temperature limitation
Old   May 9, 2004, 04:54
Default Temperature limitation
Karthick
Hello all
When I run the fluent model, I am getting following message.
"temperature limited to 5.000000e+03 in 475 cells on zone 3 in domain 1"
Why temperature is limiting to 5000K in my model. As per my knowledge, I am nowhere restricting it to 5000. But like this I want to fix my temperature rise to 1500K. Is it possible to fix like this. I am using species transport model.
Regards Karthick
Old   May 10, 2004, 06:14
Default Re: Temperature limitation
Tom
Go to....
SOLVE>CONTROLS>LIMITS
You may find with further iterations that this high tempertaure limitation will go away. Solve using first order to convergence and then try second order.
Old   May 10, 2004, 08:12
Karthick
Thanx Tom. It worked well
Regards Karthick
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
k residual goes up after temperature limitation warning??? Catthan FLUENT 0 November 24, 2010 17:48
temperature limitation? Deadly FLUENT 6 August 7, 2002 22:29
how to overcome the temperature limitation fanadam FLUENT 3 June 17, 2002 04:39
