Fluent 6.1 user guide
Old   May 5, 2004, 13:53
Default Fluent 6.1 user guide
dingdong
Hi, Can anyone help me to find Fluent6.1 user guide in the internet??
Thanks
Old   May 5, 2004, 13:54
Default Re: Fluent 6.1 user guide
dingdong
Old   May 5, 2004, 18:18
Amir
I made a 2-D non premixed combustion model for methane gas. Fuel gas and air mixture. I want to verify my results by a physical test. made the same as model a combustion chamber and will test it in couple of days. My question is how many percent error would be acceptable!? is there any number or range to show in this value of error still have right results!?! Thanks Amir
Old   May 6, 2004, 04:52
Andrew Garrard
I don't think that universities are allowed to publish the documentation on the web, because sites seem to go up and down all the time. You can find the documentation on the Fluent user service centre website and the sever is pertty fast. If not, just look in google and you will find one somwhere. Don't search for "FLUENT" because that word has more than one meaning. The search I like to use is "POROUS JUMP" that usually produces a few resutls. However if you start using it alot, it will get taken off line. Hope this helps.
Old   May 6, 2004, 12:06
co2
dear dingdong:
here you go! enjoy!
http://www.fluentusers.com/fluent61/doc/doc_f.htm
Old   May 14, 2004, 16:20
newton
The link needs id and password.
Old   May 17, 2004, 11:17
co2
well, if you are using a licensed version of fluent, you should contact fluent support to get the pwd.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Mesh (*.msh) files of User guide of fluent a_kaffash FLUENT 5 August 17, 2011 03:46
Re: FLUENT 6.2 User Guide Ahmad Hussain FLUENT 8 August 16, 2005 15:21
Parametric Studies Using Fluent 6.1 Jim FLUENT 0 April 12, 2003 10:22
Fluent 5.5. What the differences with fluent 5.3?? confused FLUENT 2 July 29, 2001 21:58
