Turbulence intensity scale
Old   May 25, 2004, 05:41
Default Turbulence intensity scale
Mirek
Hello everybody, What does mean numerical values on scale while you display contours of turbulence intensity? They are not % values! When I set at the inflow V=20m/s and choose turbulence intensity i=5% (turbulence intensity and viscosity ratio mode) then at the inflow appears value 1 (when you check it by means of surface integrals/average). If you change V or i every time you obtain X=V*i (for example 1=20*0,05). Could anybody explain me principle of creating this strange "unit" which is not percetage value? Thanks a lot in advance and best regards for every Fluent User.
Old   May 26, 2004, 08:27
Default Re: Turbulence intensity scale
Allex
Re=(V*Dh)/-1e6 Dh=4*Rh Rh=A/P I(%)=(Re^1/8)*0.16*100
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Turbulence intensity and length scale eslam CFX 3 January 14, 2008 16:37
