Data at a specific flow time
Old   May 28, 2004, 16:34
Default Data at a specific flow time
Arun
Hi!
I need to obtain values at a specific flow time. I am running an explicit case. Could anyone help me with this? Thanks
Arun
Old   May 31, 2004, 23:57
Default Re: Data at a specific flow time
Tim P.
You need to run an unsteady simulation. When you go to enter the number of iterations you want, you need to set the number of iterations per timestep and how long that timestep will take (ie. one timestep represents 0.1 seconds or one timestep for 0.01 seconds). Then enter the number of timesteps you want simulate. So if you want to extract data after 15 seconds with a timestep of 0.1 second, you'll need to set FLUENT to run for 150 timesteps. If the solution diverges try a smaller timestep.
Cheers, Tim.
Old   June 1, 2004, 21:34
Arun
Thanks Tim, but I wanted to know if there was any way I could get the data between two succesive timesteps. Sorry for not being clear abt the question. I was able to run the case from the previously obtained timestep to the next timestep using a much lower CFL number and saving the case and data intermittenly.
Arun
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
tracking data with respect to time tucker FLUENT 2 December 20, 2005 08:39
