Solver option
Old   June 20, 2004, 08:54
Default Solver option
leung
Hi all , i am a new cfd user having the following question:
1. Is that true a coupled solver is always better than a segregated solver. How can i choose the best "solver" for a particular problem?
2. what is a boussinesq parameter ? i havent come acorss this term before in my study(i am an undergraduate student)
Thank all !
Old   June 22, 2004, 16:23
Default Re: Solver option
John
Hello leung,
Well, the type of solver which would be efficient depends on the type of problem u r looking at.
Boussinesq parameter is basically used to define the bouyancy effects in any problem.
John
Old   June 27, 2004, 14:26
gopal
Coupled solver always will not give good results, some times it will give convergence problem. And also it will take more computational time compared with Seggregated solver.
Boussinique term will comes into picutre when you are solving Natural convection problems related to heat transfer. It will say that temperature has not having any significant effect in the change in density. We can use when the temperature difference is low. If the temperature difference is high we should not use Boussinique approximation.
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Has anyone successfully used transition modell..p2 PetrK CFX 12 May 26, 2006 16:27
particle tracking mike CFX 3 April 17, 2006 00:05
