unsteady problem
Old   July 13, 2004, 06:05
Default unsteady problem
kethireddy
Hi i am doing unsteady calculations using VOF model.i have initial inlet profile defined by udf. All the other conditions are defined. How long i should continue calculating ..How to check out residual of each iteration step. it would be great if somone can explain this bye kethireddy
Old   July 14, 2004, 00:00
Default Re: unsteady problem
Ajay
how long to run simulation :- Till your residuals obtain a constant amplitude.
How to check residuals :- Solve->Monitor->Residuals set the values as per your requirement and tick plot in the option to get the residual plot.
Old   July 14, 2004, 05:52
kethireddy
hi thanks for your reply.Actually i am dealing with developing waves.My convergence criteria is satisfied with in first few iterations how ever it will take time to obtain fully-developed waves of the film.i think you understand me now. waiting for ur answer regards kethireddy
Old   July 14, 2004, 18:29
Ajay
I think once you can start getting smilar pattern in your residual plot you can stop
Under Relaxation Factors(URF) in unsteady problem Maxmum FLUENT 0 August 14, 2010 18:00
conditions for unsteady problems dvdromnu OpenFOAM Running, Solving & CFD 5 November 9, 2009 02:15
unsteady state velocity problem Vedavyasa M FLUENT 0 June 28, 2007 06:33
Problem in Reporting Unsteady Particle Fates Nelson FLUENT 0 August 23, 2006 20:24
unsteady state problem prasad FLUENT 0 April 4, 2002 22:44
