May 14, 2012, 06:47 |
dynamic mesh test of a cube fails
Rep Power: 14 |
I try to test a dynamic mesh motion in order to get setup information for a much bigger simulation. For the test I use some cubes with a surround small volume in order to keep the quality of the mesh. I donīt really know wich dynamic zones have to be created. Can someone show some examples? I also have problems with the remehing tool of fluent. I tried a lot an I describe you my errors. 1. The small volume moves but the interface is switched to a wall and the volumes are not coupled. Fluent gives this note: "Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface." 2. The small volume and the big volume are coupled but I get negative cell volume. I tried to reduce timespteps and changed the remesh setting, but everytime after 0.15s it is over. I post you some pics. Thanks for your help. Regards, DSMeck |
dynamic mesh, remeshing, zones |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ANSYS Meshing] dynamic mesh problem | colopolo | ANSYS Meshing & Geometry | 8 | August 16, 2011 18:26 |
