February 15, 2009, 09:56 |
VOF && surface tension -- PROBLEM
Hi there!! I'm geting desperate because of following: I am simulating a free fall of droplet. When the droplet diameter is of 2mm, then it works quite well. Fluent results agree well with newton formula (dynamic drag considered). However, when the droplet is smaller (0.2mm in my case) then the droplet acceleration is much smaller and the terminal velocity as well. It is definetly crap.. I found that the surface tension causes this strange happening. Does anybody has any explanation for that?? many thanks!!! bohis
February 16, 2009, 10:39 |
Re: VOF && surface tension -- PROBLEM
Hello bohis
one point amongst many others may be that your mesh isn't fine enough to resolve droplets of 0.2 [mm] properly. Therefore the reconstructed curvature of the free surface and consequently surface tension effects are wrong or at least a rather rough estimation of the real situation? cheers Max |
February 16, 2009, 11:30 |
my mesh is quadrilateral. I am using axisymmetric model. I think my mesh is fine enough. Element size was 1/64 of droplet diameter for the case with coarsest mesh (1/512 for the finest mesh) for vof discretization, I employed HRIC scheme. Velocity-pressure coupling was provided with PISO. After so many calculations, I would doubt that it is even possible.. any other suggestions????????pls!!!!
bohis |
May 29, 2011, 16:35 |
Monty
Rep Power: 14 |
Hi ..
Can u help me please about droplet simulation through pipe using vof model.. thanks |
Surface tension problem. | Kes | FLUENT | 0 | May 19, 2008 22:49 |
How to get the surface tension? | summer | FLUENT | 0 | July 25, 2006 15:59 |
surface tension gradient on a free surface | Abrem | FLUENT | 1 | April 30, 2006 03:41 |
Surface tension - Continuum Surface Force model | Robert | Main CFD Forum | 0 | May 2, 2002 07:34 |
[surface tension effect at free-surface ?] | name | Main CFD Forum | 1 | September 21, 2001 09:54 |
