How to active "Spring-Based Smoothing "?
Old   September 22, 2004, 08:19
Default How to active "Spring-Based Smoothing "?
svh
I'm using dynamic mesh to make a moving pipe ,the wall is defined as a rigid body ,the cells are hexahedral ,and I have used symmetry BC.
In previewing the motion just the wall moves and fluid interior cells get deformated and it creates negative volumes. I have used bellow command to turn on the Spring-Based Smoothing method:
> (rpsetvar 'dynamesh/spring/all-element-type? #t)
but nothing changed. Maybe the settings that I put in dynamic parameters panel aren't correct , please please help me to solve this problem.
Thank you in advance.
svh
incorrect temperature in pressure based solution Kian FLUENT 1 July 6, 2009 05:59
arc based TFI smoothing? zonexo Main CFD Forum 0 August 20, 2006 22:00
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 10:23
Help me to active Spring Based Smoothing!!! Atefeh FLUENT 0 September 29, 2004 15:32
How can I active spring Based Smoothing?? svh FLUENT 0 September 26, 2004 14:13
