interface between porous and fluid
Old   October 13, 2004, 11:35
Default interface between porous and fluid
rajesh kumar
hi friends,
i have a situation where there is a porous medium and a fluid region adjacent to each other. i am getting confused as what to define the interface between the two as. fluent is showing error if i give it as interior or internal and the error message reads like this " there is only one adjacent cell thread" if i give it as interface, then the error message reads like " unassigned interface" i don't know exactly what they mean and i can't think of anything else...can some one help with this? thank you rajesh
Old   October 13, 2004, 16:29
Default Re: interface between porous and fluid
Ralf Schmidt
I had a similar problem. On the Workstation I was working on the same happend. The solution: Our CFD specialist took my data to a PC with Fluent running. On this system it works without a problem!!!
But I dont know, what kind of interface definition he used.
Ralf
Old   October 14, 2004, 13:50
rajesh kumar tippabhotla
hi thanks for showing interest in my problem. can u please find out the type of interface used by your cfd specialist. thank u rajesh kumar tippabhotla
Old   October 15, 2004, 14:02
Default INTERNAL
Ralf Schmidt
I had a look at the gambit model, we were using INTERNAL as the interface between fluid and porous.
Ralf
Old   October 18, 2004, 14:49
Default Re: INTERNAL
hi,
what is the solver you are using?does the boundary conditions depend on type of solver at all? i have tried using internal as interface between porous and fluid media. but i am getting some problem. anyway i will look into it again. thank you very much... rajesh
Old   October 22, 2004, 11:10
Default PC/Workstation
Ralf Schmidt
We are using the segregated solver, but the Problem does not seem to depend on the solver. The actual problem should be an error in the fluent code.
It depends somehow on the number of processes (or processors??) the system is using. Importing the gambit file with fluent running on a PC (with single processes) is no problem. The workstation is using multiple processes and this result in the problem you have.
So get yourself a new Fluent version, the problem should be fixed there. We have v 6.1.22, graphics version 7.01-1 (from 1998) - with this version, the problem is still there.
Ralf
Interface between fluid domain and porous domain windhair CFX 6 May 10, 2018 14:26
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 06:24
Two Domains (Porous Fluid) Acto de Lima Cunha CFX 7 April 17, 2013 21:29
Heat transfer from porous medium to fluid Ralf Schmidt FLUENT 1 October 30, 2005 06:21
access to variables at interface of porous media? Mazyar FLUENT 0 October 10, 2003 14:59
