November 8, 2004, 21:39 |
Vof simulation
Hi, every one,
I am simulating the slug flow in vertical tube by using VOF. The tube is 1m long and diameter of 10mm.I use the axisymmetry option in Fluent and make a 13*1000 grid. But in my simulating, I must set a very small time step, say 5E-5s, and for 1s simulating will cost 1 day. Does anyone have suggestions? And do you parralel cpmputer will do help with my case(because the grid number is not large)? Thanks in advance!! B. Zhao |
November 11, 2004, 22:41 |
Re: Vof simulation
hi...
plz try it... pressure : presto coupling : piso hoping you could increase the time step... have a nice day Jay |
November 15, 2004, 17:50 |
Re: Vof simulation
Hi
Is there any reason why you should set such a small time step? you may want to use the second order upwind/quick method for the momentum solver. aravind |
November 15, 2004, 21:23 |
Re: Vof simulation
Hi, Avavind,
Thanks for your answer. If I set a not-so-small time step, I will not get a reasonable result. I use the second upwind differential scheme for momentum solver. Zhao |
Mass conservation problem in mixing tank multiphase simulation | rockewan | FLUENT | 0 | April 6, 2010 12:34 |
Simulation of filling a pool by Vof | Asghari_M | FLUENT | 8 | February 16, 2010 02:30 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 02:20 |
vof simulation in batch mode | vof_grid | FLUENT | 0 | July 6, 2007 08:47 |
