Volume Fraction Gradient
Like Tree1Likes
  • 1 Post By Karl
Old   November 15, 2004, 11:31
Default Volume Fraction Gradient
Krishna
Hello all, Does any one have experience in using or writing an UDF for calculating volume fraction gradient. Any help in regards of calculating volume fraction gradient will be very much appreciated. Thanks.
Old   November 16, 2004, 23:42
Default Re: Volume Fraction Gradient
Bowling
I never see vlolume fraction in Fluent UDF. Fluent has species mass fraction gradient vector and component; C_YI_G(c,t) and C_YI_G(c,t)[i] ,respectively. You can use it immidiately. Volume fraction is mass/density. Can you adapt them?
Hope I can help you, Bowling.
Old   November 17, 2004, 02:59
Karl
This is an example from the Fluent. Maybe it will help you.
UDF used to calculate gradient for post-processing
User defined scaler (UDS) and user defined memory (UDM) are used. For any UDS, fluent will automatically calculate the gradient. So, We need to pass the variable to UDS, and fluent will caculate the gradient for you. UDM is used to save the results.
Steps to take to make it work 1. Read in the converged case and data 2. Link the udf (Define->User Defined->Functions->Intepreted) 3. Hook adjust funtion (Define->User Defined->Function Hooks->Adjust Function) 4. Define UDM (Define->User Defined->Memory 1) 5. Define UDS (Define->User Defined->Scalars 1) 6. Turn off all equations (Solve->Controls->Solution) 7. Do one iterations 8. Execute store_gradient (Define->User Defined->Execute On Demand)
# include "udf.h" # define domain_ID 2
DEFINE_ADJUST(adjust_gradient, domain)
{ Thread *t; cell_t c; face_t f;
domain = Get_Domain(domain_ID);
/* Fill UDS with the variable. */
thread_loop_c (t,domain) { begin_c_loop (c,t) { C_UDSI(c,t,0) = C_VOF(c,t); } end_c_loop (c,t) }
thread_loop_f (t,domain) { if (THREAD_STORAGE(t,SV_UDS_I(0))!=NULL) begin_f_loop (f,t) { F_UDSI(f,t,0) = F_VOF(f,t); } end_f_loop (f,t) }
DEFINE_ON_DEMAND(store_gradient) { Domain *domain; cell_t c; Thread *t;
domain=Get_Domain(1);
/* Fill the UDM with magnitude of gradient. */
thread_loop_c (t,domain) { begin_c_loop (c,t) { C_UDMI(c,t,0) = NV_MAG(C_UDSI_G(c,t,0)); } end_c_loop (c,t) } }
Geng Fu likes this.
Old   November 17, 2004, 15:49
Krishna
Hello Karl, Thanks for ur message. I did use this and the whole problem is the gradient returns the value 0 and hence when u mutliply with any thing the whole term becomes 0. If u give me ur email id I can send u the code also for ur perusal. Bye bye
Old   March 9, 2020, 17:10
mahdi rostami
mahdi-united is on a distinguished road
Originally Posted by Karl
;116170
hi
how to get mass fraction gradients with storing commands in udf
this is my code but not work.
DEFINE_ADJUST(gradient, domain)
Thread *t;
Thread **pt;
cell_t c;
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE);
real voidx, voidy, voidz=0.0;
mp_thread_loop_c (t,domain,pt)
if (FLUID_THREAD_P(t) && n_udm > 0)
Thread *tp = pt[P_PHASE];
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_YI_G(c,tp,0)[0];
end_c_loop (c,t)
mahdi-united is offline   Reply With Quote
gradient of species mass fraction zhou FLUENT 1 March 14, 2020 07:55
Volume fraction to mass fraction Torsaki CFX 10 March 10, 2018 03:41
VOF Volume fraction in Velocity inlet aruelle FLUENT 1 March 18, 2010 11:53
volume fraction, Mass fraction and Bulk Mass flow Dr.jones CFX 1 January 25, 2006 04:32
C_VOF_G for Volume fraction gradient Fred FLUENT 3 January 10, 2005 05:04
