December 8, 2004, 19:54 |
UDF and Cavitation
Hello everyone, Can I write a new cavitation model using UDF. Amir
December 13, 2004, 02:08 |
Re: UDF and Cavitation
Hi!
Check under the mass transfer in UDF documentation...there is an example of cavitation UDF good luck, MATEUS |
December 13, 2004, 21:51 |
Hi there
I am a PhD postgrad at Canterbury University and engaged in CFD modeling of photoreactors as applied to water treatment; interested in implementing CFD as a tool for acquiring new insight into improving reactor design ,i.e integrating hydrodynamics and kinetics of hydroxyl radical formation in the UV radiation activated reactro space. I am aware from experimental research that cavitation is iused in proprietary commercialised processes to speed up rdaical formation from hydrogen peroxide solutions in waste water with of course the help of UV radiation absorption into water: My problem as follows: I want to use a valid cavitation model inside a cylindrical annular reactor and integrate it with available literature kinetics to predict photodegradation ,i.e concentration profiles of a toxic chemical in wastewater or energy efficiency of the reactor? Can you assist with a UDF cavitation model ASAP Thanks Derya Kibar PhD student in Chemical Engineering |
December 14, 2004, 02:04 |
Hi!
My experience is that the "official" Fluent 6.1 cavitation model works ok...I'got some very good results with it but on the other hand it took me more than a half of a year to get there. And it only worked for unsteady simulation. Older Fluent versions have a simplified cavitation model implemented which (at leas in my experience) doesn't work... Hope you make it, MATEUS |
HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 5 | December 3, 2016 17:53 |
UDF save data to a file!! | spk | Fluent UDF and Scheme Programming | 34 | July 17, 2013 14:03 |
vaporization pressure UDF | Komon | Fluent UDF and Scheme Programming | 0 | September 20, 2011 19:33 |
difference between cavitation and UDF by yourself | qiyang860908 | Fluent UDF and Scheme Programming | 0 | November 15, 2009 04:04 |
using UDF in Fluent for unsteady cavitation | Pejman | Main CFD Forum | 6 | November 6, 2008 10:18 |
