Thanks for any advice!!!!!!
Old   January 28, 2005, 11:34
Default Thanks for any advice!!!!!!
laoquange
Hi,every one:
I try to resolve this type case which simulate the pollutant flowing in the indoor air, and the pollutant diffuses from the building material of indoor that is solid. The diffusion procress is govened by the Fick equations that is similar with one dimensional transient heat conducting equation. My problem is how to couple polluatant diffusion equation for solid with the fluid equation. Thanks in advance for anyone give me some advice.
Old   January 30, 2005, 09:12
Default Re: Thanks for any advice!!!!!!
Swarup
Hi, you may try modeling scalar transport without reaction or you may use a User Defined Scalar (UDS).
Old   January 30, 2005, 22:55
Jeffery
Consider wall as pourous and set appropriate parameters!
Old   January 31, 2005, 05:08
laoquange
Thank you for your response. But how can i got the pollutant diffuse rate from the building material? At the assumption that we have got rate, and how can we couple it with the flowing equation? Thanks you again.
Advice for a Beginner Dave442 ANSYS Meshing & Geometry 5 September 16, 2011 07:03
sonicFoam aerofoil advice MikePo OpenFOAM Running, Solving & CFD 8 May 26, 2010 04:34
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
HELP: advice for future research sunlight Main CFD Forum 1 May 21, 2004 10:23
advice needed! Filip Main CFD Forum 2 April 26, 2002 15:27
