Rotating Vessel: Problem Set-Up
Old   February 4, 2005, 05:41
Default Rotating Vessel: Problem Set-Up
Harmeet
Hi everyone!
Would like to check with you please, about my problem setup.
I have a vertical cylinder that has its fluid inlet at the bottom and the outlet at the top.
My vertical cylinder, however, is spinning about 2 axes: spinning about the vertical axis and tumbling about the horizontal axis. In other words, bi-axial rotation.
I believe that this is a steady state problem. The question is:
- To set up the problem, all I need to do is to go to Boundary Conditions, select my vessel wall and specify the angular velocity, right? This is what is called a moving reference model I believe? Thanks people! Cheers!
Harmeet.
Boundary Condition For Pressure vessel Problem abhayachougule Main CFD Forum 2 October 26, 2010 07:48
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
Rotating blades fan problem Luk FLUENT 1 June 27, 2006 09:56
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 5 May 12, 2006 18:42
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 0 April 28, 2006 05:45
