complex roughness pattern
Old   February 6, 2005, 17:28
Default complex roughness pattern
Tarnz
In the new Fluent Beta Version it is possible to read in a profile file with roughness parameters for specifying the wall boundary conditions. I am not sure how to create this file. Has anyone done that yet and/or can help me? Thanks
Old   February 10, 2005, 12:10
Default Re: complex roughness pattern
giorgio
I dont' have that beta version of fluent but I guess you can export from fluent a profile file similar to the one you want to create.
After that look at the structure of the exported file with a simple ASCII editor (e.g. notepad) and try reproduce the same structure to a new file containing the roughness parameters you want to assign.
Fluent should be able to import the file with the changed parameters.
To make the procedure easier you can use different softwares like explorer, 123, mathcad, mathlab or others
Old   February 24, 2005, 21:45
Tarnz
Grazie mille, Giorgio It looks like this is the only possible way. It is quite time consuming with this big, complex surface I am working with, but it seems to work. Thanks again Tarnz
Old   February 25, 2005, 04:55
giorgio
Di niente Tarnz. I think you can find in the fluent website an usefull tutorial in which is used an udf that build your profile of bc in a easier way. I didn't use that udf but a student in my uni did it for a VOF model (air over water).
it will speed-up the implementation of your cases but it wont affect the numerical results
regards,
giorgio
ps: at the moment i'm working on flow over complex terrains so it would be nice to compare some results. Don't esitate to contact me whenever you want
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
How to apply variabe roughness, e.g. to complex terrain? Fridolin OpenFOAM Running, Solving & CFD 3 August 12, 2020 15:09
NACA standart roughness DAK565656 Main CFD Forum 2 August 24, 2005 00:47
Roughness adaptation in CFX 4.4 Bart CFX 1 May 2, 2003 08:32
