November 17, 2014, 06:02 |
compressible fluid
Reza
I want to model a flow of compressible fluid in the tube with Mach number 1.1
Which one of the viscous model should I choose? What specific settings should I do? |
November 17, 2014, 23:49 |
Lucky
Rep Power: 66 |
All the models are valid for compressible flow to some degree. Which model you should use will depend on what type of flow problem you have. Some of them will be obvious, i.e. inviscid vs laminar vs turbulent. I think you should start with figuring out which of these 3 you have.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
rhoSimpleFoam for compressible fluid through an orifice | WillemvdM | OpenFOAM Running, Solving & CFD | 2 | June 20, 2012 03:54 |
What is the total energy for incompressible fluid? | Harry Dong | Main CFD Forum | 12 | February 4, 2006 00:55 |
Fluid Structure Interaction | Apollo | FLUENT | 8 | July 7, 2004 17:54 |
