what's relationship between flow rate and speed
Old   April 4, 2005, 20:29
Default what's relationship between flow rate and speed
wanghong
Hi everybody.
i am simulating a species problem.i know when gas flow rate of the nozzle is a constant,a small diameter will make gas flow faster,but what's relationship between the speed and diameter and nozzle's flow rate?
Thanks for all!!
Old   April 4, 2005, 23:11
Default Re: what's relationship between flow rate and spee
pUl|
Equation of continuity?
v1 * rho1 * A1 = v2 * rho2 * A2
Where:
v = velocity/speed (m/s)
rho = density (Kg/m^3)
A = cross sectional area (m^2)
Assuming rho is constant:
v1 * A1 = v2 * A2
=> Flow rate = v * A = constant
=> if 'd' decreases (because A = pi() * d^2 / 4 => A also decreases) then v increases to keep v * A = constant.
Best Regards,
Srinath Madhavan
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Accuracy and convergence pawan1989 FLUENT 5 April 15, 2010 17:17
high speed flow with air dissociation Victoria FLUENT 1 May 5, 2006 11:53
high speed flow with air dissociation Victoria Main CFD Forum 0 May 4, 2006 06:46
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
