postprocessing problem
Old   April 8, 2005, 22:46
Default postprocessing problem
wanghong
hi,all.
when a species transport equation is finished,i want know the contours of velocity in a plane of 30 degrees inclination angle from the horizontal .How to define the inclination plane ? Thanks.
Old   April 9, 2005, 11:35
Default Re: postprocessing problem
Jason
Make sure to set your axis for the Fluid (Define->Boundary Conditions->Fluid... set the location and direction of the axis so that the axis is the axis of rotation of the plane that you want). Then create an isosurface (Surface->Iso-Surface) of constant Grid -> Angular Location and set it to 30degrees. Remember that 30degrees is based on the right-hand rule for the axis you defined for the fluid.
Changing the axis doesn't change any of the flow solution, because the flow was solved in cartesian coordinates. This axis is used for post-processing.
Hope this helps, and good luck, Jason
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
