May 1, 2005, 17:32 |
Error when compile UDF file
Hi, I tried to compiled UDF file and it gives me this error: 'nmake' is not recognized as an internal or external command, operable program or batch file
Any solutions? Thanks in advances Lee |
May 1, 2005, 22:52 |
Re: Error when compile UDF file
Do you have MSVC installed and the ENVIRONMENT/PATH set correctly?
May 2, 2005, 12:54 |
Thanks for response. Where can I get MSVC? How to set ENVIRONMENT/PATH? Thanks
May 3, 2005, 06:43 |
I think you have to install a C compiler. I had the same error so I installed Microsoft Visual C++ and the problem go away
May 3, 2005, 06:52 |
Yes, you need MSVC and when you install it enable the panel "set-environment variables". Maybe I'm wrong bui you can download it from MS web site. Give it a look. Luca
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
