2nd order divergence
Old   May 16, 2005, 20:14
Default 2nd order divergence
Reg
Hi, I am modelling a cavity (L/D=5) with flow speed M=0.85. It's a 2-d very fine quadrilateral mesh so I do not think I should need to refine further to solve my problem. I am able to get a converged 1st order unsteady solution but when I switch to 2nd order discretization, my solution blows up (specifically, continuity residual). I am using a segregated solver. I have tried decreasing under-relaxation factors (down to 0.3!) and time steps significantly (down to 1e-8!) and iterating, and still no luck.
FYI, I am using Fluent 6.2.16. Turbulence model is k-omega SST with transitional flow, compressibility effects and viscous heating options all turned on.
Any suggestions out there?? Thanks in advance, Regina
Old   May 17, 2005, 03:08
Default Re: 2nd order divergence
Luca
Yes!use the coupled solver.Luca
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
IS calc. with 2nd order discret. always necessary? Azman FLUENT 2 March 14, 2013 04:28
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Unstable flow simpleFoam 2nd order Valle OpenFOAM 0 August 26, 2009 08:12
