vaporization and Material removal
Old   May 5, 2005, 08:57
Default vaporization and Material removal
m.sundar
Hai fluent users
can any one give idea for my laser cutting problem.
wheather it is possible to remove the material(vaporization) by applying heat.
Actually beyond certain temperature all the materials will start to vaporize.Can this vaporization be modelled in fluent.
Thanks in advance
M.Sundar
Old   May 7, 2005, 21:24
Default Re: vaporization and Material removal
Joey
As far as I know, vaporization can be simulated by Fluent, using UDF.
Old   May 9, 2005, 23:55
Harish
I have a friend working on a similar problem. Laser is a high speed process and hence shock waves can be generated and the schemes available in fluent might dissipate the shock.The best way to solve the problem is using SCM. The best would be ENO schemes with relaxations.
-H
Old   May 10, 2005, 01:10
m.sundar
Dear Harish
Can you please explain how to deal this problem, or can you give yours friends e-mail.
thank you
Vaporization Phase? Jason FLUENT 0 March 4, 2007 22:01
True-VOF vs. False-VOF edi ghirardi FLUENT 7 May 24, 2005 02:10
